exhaust port waterline *LINK*
Posted By: Mike Dolan
Date: Monday, 20 June 2005, at 2:15 p.m.
Guys,
I have Mercruisers 454's. I installed a 240 gallon gas tank in the cockpit this year.
As expected the addition 500 lbs or so has raised the waterline a little.
Prior to the new tanks the exhaust ports were about 1/2 covered by water when fully fueled. Now they are about 3/4 covered. So I expect them to be fully covered with a crew, ice and bait.
Will this be a problem. Do I need to raise the exhaust ports? Should I put some weight in the Anchor locker to bring the stern up?
The max head pressure at 4" is about ".1 PSI", I can't imagine that a big block would have a problem with this?
any thoughts?
http://www.lightningshack.com
Mike Dolan -- Monday, 20 June 2005, at 2:15 p.m.
Re: exhaust port waterline
phil kindla -- Monday, 20 June 2005, at 2:40 p.m.
Scott Deskins -- Monday, 20 June 2005, at 3:09 p.m.
