Re: Wet foam removal on a B20
Posted By: Ian Upton
Date: Thursday, 16 June 2005, at 3:16 a.m.
In Response To: Re: Wet foam removal on a B20 (Walter Kaprielian)
Walter,
Are you suggesting removing some of the foam outboard of the stringers to make some sort of stowage compartment?
If so make damn sure that everything is sealed up and any water that gets in there won't find its' way to the foam.
Ian.
- Wet foam removal on a B20
Rocket -- Monday, 13 June 2005, at 10:38 p.m.
- Re: Wet foam removal on a B20
Peter -- Monday, 13 June 2005, at 10:56 p.m.
mike ohlstein -- Monday, 13 June 2005, at 10:59 p.m.
Rocket -- Monday, 13 June 2005, at 11:46 p.m.
Ian Upton -- Tuesday, 14 June 2005, at 12:30 a.m.
Dug -- Tuesday, 14 June 2005, at 8:07 a.m.
Peter -- Tuesday, 14 June 2005, at 10:22 a.m.
Rocket -- Tuesday, 14 June 2005, at 11:27 a.m.
CMP -- Tuesday, 14 June 2005, at 11:30 a.m.
mike ohlstein -- Tuesday, 14 June 2005, at 11:45 a.m.
Ian Upton -- Tuesday, 14 June 2005, at 11:31 p.m.
Rocket -- Tuesday, 14 June 2005, at 11:57 p.m.
Walter Kaprielian -- Tuesday, 14 June 2005, at 10:25 a.m.
Ian Upton -- Thursday, 16 June 2005, at 3:16 a.m.
Walter Kaprielian -- Thursday, 16 June 2005, at 10:11 a.m.
Robert Rae -- Tuesday, 14 June 2005, at 1:58 p.m.
Rocket -- Tuesday, 14 June 2005, at 9:58 p.m.
