Hot Vac
Posted By: Mike
Date: Tuesday, 31 May 2005, at 10:17 p.m.
I was wondering if anyone had hot vac the bottom of there 31? My boat has been on dry dock for a little over a year. I tested it with a moisture meter and it was still wet. I am not sure if I should use this method to dry the hull. My concerns what will the heat due to hull. Thanks in advance.
Hot Vac
Mike -- Tuesday, 31 May 2005, at 10:17 p.m.
Re: Hot Vac
Pete Fallon -- Wednesday, 1 June 2005, at 1:10 a.m.
