Re: Drain
Posted By: bruce doan
Date: Wednesday, 18 May 2005, at 7:56 a.m.
In Response To: Drain (Mike G)
The first year I had the same problem, so I removed a fitting. The following year I installed a drain near the stern, problem solved[wrong]. The next year the yard blocked me stern up, my forward bildge pump was incased in ice. I put a second drain in the middle bottom of cabin area and I don't care what position the yard blocks me in. The drains also helps clean bildge in spring
- Drain
Mike G -- Tuesday, 17 May 2005, at 8:42 p.m.
- Re: Drain
Wayne -- Tuesday, 17 May 2005, at 8:57 p.m.
- Re: Drain
John F. -- Tuesday, 17 May 2005, at 9:20 p.m.
- Re: Drain
Rich H -- Wednesday, 18 May 2005, at 7:18 a.m.
- Re: Drain
Tony Meola -- Tuesday, 17 May 2005, at 9:42 p.m.
- Re: Drain
Walter Kaprielian -- Tuesday, 17 May 2005, at 11:03 p.m.
- Re: Drain
Harv -- Tuesday, 17 May 2005, at 11:20 p.m.
- Re: Drain
Scott Deskins -- Wednesday, 18 May 2005, at 7:37 a.m.
- Re: Drain
bruce doan -- Wednesday, 18 May 2005, at 7:56 a.m.
- Re: Drain
Rawleigh -- Wednesday, 18 May 2005, at 1:25 p.m.
- Re: Drain
Mike G -- Wednesday, 18 May 2005, at 5:51 p.m.
- Re: Drain
BOB FIORESI -- Wednesday, 18 May 2005, at 8:52 p.m.
