Re: Uncle Vic's 20 Bahia Mar
Posted By: Ian Upton In Response To: Re: Uncle Vic's 20 Bahia Mar (Vic Roy)
Date: Thursday, 18 November 2004, at 8:44 a.m.
Jim,
Sounds like you will have a fantastic boat when you are through.
Coming from UV and knowing that the boat was in covered sling storage, this should not be a problem, but you should check into water logged foam under the floor.
Are you planning on putting together pictures like Capt. Patrick did?
Ian.
